Build from old Parts
I'm a woodworker but know almost nothing about speaker design. A neighbor gave me the following parts, apparently purchased in early 2000's(?) but never used, and which I'd like to use to build speakers for my ~1,000 sft basement shop:
-An AR.COM two-way (bookshelf?) speaker kit, with a pair of Peerless 850122 woofers, Peerless 812687 tweeters, and crossovers.
-A pair of NHT 1256 woofers
My question is - is it a reasonable idea to use these parts in a pair of three-way speakers? I can build the cabinets to any required volume, but I'm totally incapable of designing new crossovers if needed.
Recommendations appreciated - Gus
I built a pair of the AR.com speakers. The Peerless 850122 is a terrific mid bass. The same can't be said for the 812687 tweeter but it's serviceable. The crossover designed by Ed Frias lacks baffle step compensation resulting in bass that's a little thin. Scroll down the enclosed link to Dennis Murphy's revised crossover design. Much better than the original Ed Frias crossover.
I believe Danny Ritchie at GR Research also re-designed the AR crossover, but the schematic is not on his web site currently. If you send him an e-mail he may be able to fix you up if you're interested.
So I would build the AR's and a pair of matching powered subs using the 1256 woofers. Trying to build three-way speakers out of the parts you have would necessitate designing a whole new crossover.
Calling Ed Frias (AR.Com ?)
OK, thanks all for the feedback. I understand the recommendation to house the subs separately and yes they are in fact NHT 1259's
The 1259's will be connected to an 110 watts/channel Onkyo TX-NR709 receiver, and it appears that the receiver requires active/powered subwoofer(s) to function properly. Thus additional questions:
-Can I use the 1259's with a plate amplifier in the cabinet? Based on Googl'ing I see 1259's require about 3.3 cu ft volume sealed cabinets - apart from expanding slightly for the volume taken up by the plate amplifier, does the volume requirement change for the powered configuration?
-On Parts Express I see Dayton Audio and Yung brands with good reviews - any opinions? Options include No Boost, Class D, 6DB at 30 Hz, DSP .... opinions? I know nothing about this stuff 🙁
-I'm setting this up in my 1000 sft basement shop - since I have two 1259's are two subs better than one? How many amp plate amplifier do I need? (I like good bass but I won't be playing at real loud volume - I have neighbors nearby)
Thx, Gus
