Hey,
I own a pair of Tannoy 402 Studio monitors and i was wondering, is it possible to buy a subwoofer(the monitors cant go low enogh), and some electronics to make a portable speaker out of them?
If yes, i would appritiate if some1 could tell me what commponents to look for that will work with the drivers my monitors has in them.
Here arew the monitors specs: https://www.sweetwater.com/store/detail/Reveal402--tannoy-reveal-402-4-inch-powered-studio-monitor
thanks!
thanks!
I'm sure you can do what you're asking. You can find subwoofer plate amps many places. For example, Parts Express Plate Amps
Find a subwoofer you like, something like this- Tang Band Subwoofer or one of many others.
The main issue, in my opinion will be power if you are intending on not using AC. You'll need a hefty battery source to play this for any amount of time. With the subwoofer I linked, you would need a .33 cubic foot (internal dimensions) added to the two Tannoy monitors. You might be able to build smaller enclosures for them, so that could help with the size.
There are plenty of other woofers and subwoofers you can use. I just posted a suggestion.
Mike
Mike
