Bugle power supply
Dear binspaul, you are incredibly inconsistent in the data you supply, it´s IMPOSSIBLE to answer if you keep changing things all the time.
1) up to post#12, we were talking a +/-15V supply, fed from a 18+18V transformer (originally), switched to 15+15V in post #12 .
Then without explanation you switch from +/-15V rails to +/-24V 😕
That alone invalidates all earlier calculations and answers 🙄
Even worse: by rising regulator voltage (24V) and lowering transformer voltage (15VAC means meager 21V peak/raw rail voltage) makes their work IMPOSSIBLE.
Do you realize that? 🙄
Hey, earlier you said it was
PLEASE decide on one value and stick to it.
Then you have a shorted preamp.
If the amplifier shorts and burns the Power Supply then you DO have an issue with the Amplifier. 😎
Hello,
I am extremely sorry for the confusion created. The thread was started to discuss the Hagerman Bugle Power Supply for using in a phono pre amplifier project. After the few posts and discussions, the transformer required was confirmed to 15-0-15 center tapped.
Instead of creating a new thread, I used the same thread to discuss on using the Bugle power supply board to power the Pass B1 Buffer preamplifier. As I am having extra Bugle power supply boards and components, I was planning to use the same to power the B1 project (if possible).
1. Since B1 requires a higher input voltage, I switched the transformer to 18-0-18.
2. The resistor value is 10R @ 500mW (sorry for the typing mistake)
3. I am also assuming that there seems a shorting in the amplifier board which I need to find out.
4. Will there be a short if I reverse the JFET's?
5. I am using the original B1 buffer preamplifier and is only using the POSITIVE and GND from the bugle power supply. The NEGATIVE section is unused.
Best regards,
BP
