I'm thinking of building a Bugle phono preamp but it seems digi-key does not have the 0.01uf and 0.22uf polypropylene capacitors anymore. Does anyone know which capacitors I can get from digi-key that would be a good replacement? Can I use any capacitor as long as its the same value?
Probably a good idea to stick with the same tolerance as well. They have 63V Vishay film caps in stock, just check the lead spacing for a perfect fit.
BC2054-ND
BC2062-ND
jeff
edit: You could email Jim for an updated parts list.
You might want to look at these two threads:
Need Bugle cap substitutions
Bugle Parts Substitution Questions
