Buffers high freq loss
when looking in Operational Amplifier (such as LM833) data sheet , can see that power band width is constant in the audio frequency region.
when passing guitar signal through buffer (consists from LM833 or any similar), high frequency loss is noticed, can any body explain why is that??
I referred to basic buffer circuit (attached jpg)
Or try this,
the emmiter resistor needs to be low to give decent output current capability.
The base need to be given a reference voltage of VCC/2 approximately hence the two 47k resistors. The output cap needs to be fairly large to ensure no LF roll off into low impedance loads.
In your opamp above the LM833 isn't ideal for a 9volt (battery ?) Try a TLO71 (single) or TL072 (dual)
The bjt shouldn't lose highs as you put it. Are you certain the transistor is connected correctly ?
It should drive any normal preamp/power amp input OK
The voltage on the base should be around 4.5 and with around 4 volts on the emmiter if using 9 volt supply.
LM833/NE5532 are a bit power hungry compared to TLO72.
Noise and distortion tbh is the last to worry over here. Noise is also determined by the surrounding components and the values used... honestly, it's a non problem for you here... same goes for distortion. The NE5532 is preferable for driving low impedance loads <2k
Your battery will last several times longer with the TL072... and if battery life is very important there is the low power TL062 (not as well specced).
General rule is to keep impedances as low as practicable... more so for bjt devices (such as the NE5532). FET opamps work well at mid impedances such as 20k feedback/input resistance.
Now put it all in perspective... you won't notice any sudden increase in noise swapping from a 5532 using 1k resistors to a TL072 using 47 or 100k.
Yes in theory and practice the noise does increase... but it's all down in the -110db range or thereabouts anyway where a few db just doesn't matter to all practical purposes.
Of far far more importance is construction/layout and the power supply... honest 🙂
