What about using cheap coaxial cable? Is coaxial geometry a bad idea for speaker load engineering?
There's old pure copper coax surplus around with loads of copper eg 13AWG giving low resistance and less then a dollar a foot. It will be dam stiff and bit of a hassle to connect.
Specs:
Conductor DCR: 1.9 Ohm/1000ft
Shield DCR: 1.5 Ohm/1000ft
Nominal Characteristic Impedance: 50 Ohm
Inductance: 0.08µH/ft Nominal
Capacitance: 29.5 pF/ft Nominal
Velocity : 65% Nominal
Delay: 1.4 ns/ft Nominal
Specs:
About any geometry will do.What about using cheap coaxial cable? Is coaxial geometry a bad idea for speaker load engineering?
Coat hanger wires do fine. They came in the best ones in a blind test.
Audiophile concensus is polluted by snake oil vendors and self claimed experts.
Concensus is by no mean a dependable reference.
No. It is merely an unnecessary idea, unless you suffer really badly from RF interference. In addition, you would need quite thick coax to get the low resistance of more normal speaker cables. Thick coax is usually expensive and inflexible.jazap said:Is coaxial geometry a bad idea for speaker load engineering?
You could parallel 6 and get ~8 Ohms and we could loop back or branch to any number of previous threads. 😀
Six parallel coaxes would be even more expensive and inflexible. Of course they would have to be exactly the same length, otherwise the music would arrive at different times so PRAT would be poor.
Come on, now... Even *I* got the joke...
Sometimes two coaxials are used "cross connected"I thought that the general concensus was that shielding on speaker cable was bad...
Just use thick copper wire. No need for fancy stuff.
We don't use fancy wire created by elves in the moonlight in professional studios. The production gear is hooked up with copper, the only difference is we use decent connectors so it can withstand a lot of plugging/unplugging.
Besides, the internal wiring of speakers also uses standard copper cabling, unless you're buying woo speakers made to impress people with their price.
My thoughts exactly. I am not aware of any professional studios here in Music City using any cabling that costs thousands of dollars per meter. Mogami, Canare, Belden, Gotham, Sommer, etc is what you see used.
How does a recording made with these studio cables become magically transformed, when a 10,000usd interconnect set of cables are used or a 5000usd AC power cable is connected in the home audio system.
Wow. Car salesmen have nothing on the so called high end audio sales!!
What does the cross connecting do?
I've got about 200' of RG59 coaxial cable. I could easily give this a go.
Cross connecting I just using two runs of coax to one speaker. But instead of simply paralling them, sever them halfway, then reconnect them but shield to core and core to shield.
All it does is retain the same capacitance and resistance, but adds some inductance.
I had calculated the effective inductance for Jon years ago, he eventually confirmed my analysis.
But, it's nothing magic.
Jn
Hmm, been about 15 years, I think I described it correctly..
I use Mogami good solid product at a sensible market price.
No, I know how to do it, but I just don't understand what it does, in actuality. I mean, instead of crossing the cables, couldn't you just as easily strip back the plastic insulator, like 1-2" from each end of a single run, and solder the shielding to the conductor? Is there a function to the crossing?
Copper plating works for ethernet at short runs (it does pass the HF qualification test), but it does not work well for PoE and definitely iron is a very bad speaker cable.
Nonsense. All data cable is specified for 330' including POE.
Belden cable, Canare connectors, job done 🙂
If you don't want to make cables yourself - go to Blue Jeans.
Anecdote: 15 years ago I needed 20m component cable (video) for 1080p to hook up my video beamer. People on internet fora said I'd need ridiculously expensive cables for that length and resolution.
I talked to Blue Jeans, they guaranteed(!) me their cable would work perfectly, made me a custom cable to length, shipped it to Europe.
Still much more affordable than anything I could buy here (guaranteed to work), and it worked perfectly - no signal degradation whatsoever, perfect picture.
These guys make quality cables without the audiophile/videophile bullshi*, and they will stand by them - proper return policy if you're not happy with them.
Speaker Cable at Blue Jeans Cable
On second thought, that's not gonna work, since the the shielding is steel. LOL
Speaker cables don't need shielding anyway 😉
- Design & Build
- Parts
- Budget audiophile speaker cables
