BT 50Wx2 Class D Amp board in a custom box
Hello, I want to put a Bluetooth TPA3116D2-based Amp board into a diy mdf or wooden box with inside dimensions 5" x 5" x 2" instead of the boring aluminum box of about the same size it comes in.
I've read that the chip might get very hot. Was wondering if I have to make holes in the box to help with heat dissipation or a sealed box would be fine? What is the general rule?
Thanks, h
Thanks, cacao! To be on the safe side, I'm leaning towards drilling a few holes above the heat sink and a few in the bottom for the heat to escape. Or, if I find them, put tiny grills in the top and bottom. The board was originally in an aluminum case, and I want to put it in a small sealed mdf box.
There are a lot of diy Bluetooth portable speakers in all-wood enclosures using small amp boards with Bluetooth. Don't remember many of them mentioning shielding. Is it because the sound quality isn't expected to be high anyway? Or is it because these boards do not suffer from interference that much?
Thanks M2H!
If I keep the original aluminum case, would it be possible to put it inside a new wooden box, then extend the wires through the original case holes for the controls, BT antenna, audio outputs, power supply, etc. and install them at the new wooden back and front panels?
