Bruno Putzeys Kii Speakers' technology
The interesting part in my experiments is not the forming of a cardioid pattern with two separate boxes, but doing the same with only one acoustic enclosure, and the space savings this allows. There's a lot of mutual interaction going on between drivers that are reproducing different signals.
Yes, the rear driver's response needs to match what actually wraps around the cabinet. IOW, measure your target response at 180* while driving only the front speaker.
Using 2 boxes, spacing may be large enough that results are more about baffle size than beaming per se. Fortunately, you're currently working on engineering, not acoustical theory. 🙂
That makes sense to me, thanks. Hopefully I can try this weekend
