Hi Ketje, I don't need gain in my system.
So I connected directly to the BCF skip the LTP.
I used 20 K resistor for the BCF and 20.75K to compensate for the gain difference in the two inputs, this minimize 2nd harmonics and it worked.
I made it simpler 🙂
I used the bypass CAPS because the design is already operating at full feedback.
The caps makes the output impedance lower and I connected a jumper for bigger output caps to drive directly my HD600.
It sounds very nice but it is due in part to the overkill built.
I made it simpler 🙂
Shure, but with that pot-meter you can adjust the gain from -∞ to a bit more then +5Hi Ketje, I don't need gain in my system.
Mona
