I acquired one of these, cheap, from a thrift store, I bought it just to pick up the 2A3's even though different brands. But before I ebay'd it, I thought I would just take a risk and see if it worked. I know, use a Variac or a series light bulb, I did neither
Well, it sounded incredible, even though I had to run CD player through one of 6 phono equalizer networks. It's the first mono amp I ever heard, that didn't make me wish I had stereo. It rocked the garage playing Dire Straights. Lots of bass! So I let it run for awhile, then I heard a couple POPS and shut er down. (It was still playing).
Took it back apart (not easy). looks like a 40uF cap opened up, that is downstream from a 47k resistor, and the solder connections to the series 20W, 700 ohm resistor were loose. I tagged the wiring, took everything loose off the terminal strips, because they looked sad. Replacing the cap, looked like it was going to be no problem, as I had some NOS Mallory 50uF/200VDC caps in my spares. Looking on line though there is at http://www.stormkingny.com/Downloads/index.htm
a drawing from 1953 that showed this cap rated at 450VDC. I don't have one handy. Can anyone see if this was just being overspec'd by a draftsman, or does it need to be that high a voltage. I believe it supplies the negative bias, so I can't think why it would need to be this high. Thanks, and does anyone actually have one of these? Oh the reason it was still playing was because someone had put a 15A fuse in!
Sparky,
I think you are talking about C200, which is intimately associated with the B+ circuitry. Damned right you need a replacement part rated no less than 450 WVDC. $12.07 buys a nice Vishay/Sprague "Atom" from Mouser. Mouser's stock # is 75-TVA1712.
BTW, the late Paul Klipsch liked Brook amps. Maybe you need to hunt a 2nd specimen down.
Can you help clarify for me why the 700 ohm 20W resistor is in the CT leg of the power supply? Is it setting a negative supply voltage relative to ground "downstream". The schematics for the Brook add in things inplaces that make it hard for me to understand what's going on. The schematic doesn't seem to show what is actually at ground potential. I'm speaking of the schematic shown on my previous message, not the ones floating around on the internet that aren't complete and don't match thea ctual amp very well.
Thanks and pardon my ignorance.
You are correct that this resistor does set the bias for the output tubes. The way it does it is that all grounds for the entire amp run through this resistor including the CT of the output tubes filament transformer. The exception is the grid of the output tubes. Notice it's ground reference is the CT of the power transformer secondary. Therefor, the ground potential of the entire amp is at the same voltage as the bias for the OP tubes.
This is a common way to establish a bias without having a separate bias supply.
One could learn a lot from studying this schematic, thanks for finding it.
So to your understanding, would there be any reason for a 450 volt rating on that capacitor, like the original drawing shows, over one having only about twice the bias voltage? I think the 160v 40uF cap was an original. I'm thinking or replacing all 3 wirewound resistors with Dale heatsink resistors, mounted to an aluminum plate held by 2 screws where the original solder terminals were mounted. The next big fun thing will be replacing the 3 element FP can capacitors. That will be a pain due to the number of wires tied to them and the can grounds. Needless to say, star grounding wasn't used. This mod wouldn't be readily visible, unless one removed the bottom plate. The original 700 ohm wirewound resistor bubbled off some of its vitreous enamel in one spot but still measures 700 ohm. I feel like extra caution is okay due to it being bias supply. Thanks
Don't skimp on the voltage rating. First, line voltages tend to run higher now than they used to. Second, the high temperatures present in a tube amp are deleterious to capacitor reliability; a healthy de-rating should be the rule. Third, voltages can swing around a bit during warmup when tubes aren't drawing current.
450V caps are cheap and easy. Why risk booms and sparks? I'd even go higher.
I'm not against putting in a higher voltage cap, I even have some Xicon which I could use temporarily. It's just that I'm tried to understand the circuit better. What voltage should I expect to see from the hot side of the 700ohm to ground. The negative bias voltage I'm thinking. About -45 volts in other words. Thanks
If you are talking about C200, there is at least 300V across that capacitor when the amplifier is operating and drawing its normal idle current, during warm up it will be higher. (C200 is across the supply from cathode to center tap and sees the full supply voltage at all times.) A 450V capacitor is advisable.
I would expect about -45V to -55V across that 700 ohm resistor, and yes it is effectively the grid bias.
You're talking a fairly valuable and collectible amplifier, might as well do it right the first time.
Hi again..
Can someone recommend a good spray flux remover or other process to remove some of the build up of 56 years. (I don't think I want to try the dishwasher, over treatment) This thing looks frightful in some ways. Really tight construction. And the flux residue makes it hard to see the solder joints clearly. I don't want to remove lettering or finishes. Are there some flux removers that are a real no=no on vintage equipment? I'm half tempted to part with this thing, as i'd want to replace the leads from the xfmrs and get rid of all the preamp components and tone controls. Or just bypass them to one of the phono plugs. Any thoughts, it did sound really good, for a short while, but I don't see it as anything other than a historically valuable piece. But I don't have much in it yet. Once I start replacing things it's hard to see where to stop!
Sparky OR said:Can you help clarify for me why the 700 ohm 20W resistor is in the CT leg of the power supply? Is it setting a negative supply voltage relative to ground "downstream". The schematics for the Brook add in things inplaces that make it hard for me to understand what's going on. The schematic doesn't seem to show what is actually at ground potential. I'm speaking of the schematic shown on my previous message, not the ones floating around on the internet that aren't complete and don't match thea ctual amp very well.
Sparky,
the 700 ohm resistor creates a drop which is the bias for the 2A3's.
This is called back-bias.
http://www.ampslab.com/vintage_brook22a.htm
The secondary of the transformer, the rectifier and first cap are not grounded. The ground is at the second cap, just after that resistor.
So the full current of the amplifier, having to go through that resistor to close the loop, generates a negative voltage drop.
Approx. the total current should be around 90 mA (approx. 80 mA for the output stage, i.e. class AB1 operation) and should give a bias of about 62V.
The 47K resistor and 40uF cap before arriving the grid resistor is an additional filter. So it can be low voltage.
The first cap of the supply must be high voltage because you should have 300 + 62ish + some small drops.
400V seems to close to the limit and even if it can work it will not last!
450V is a more logical chioce.
Sparky OR said:Hi again..
Call it an exercise in curiosity, perhaps if you study the schematic carefully you will see a point where you can connect a repurposed rca jack directly to the input of the amplifier. I think if you take the time and trouble to restore this piece you will find it much more than a historical curiosity - it should give a modern amplifier a fairly good run for the money.. Brook amplifiers deserved their reputation at the time, and frankly in many ways still do. I just wouldn't do anything that isn't readily reversible, OTOH it is YOUR amplifier so who am I (or anyone else for that matter) to dictate what you do with it?
Straight isopropyl alcohol sparingly applied with an acid brush, Q-tips (tm) or similar is generally what I use to remove old flux, blot with very absorbent paper towel.. Again some patience is required..
thanks for the help...I'm beginning to get a plan on this. But it does look intimidating, I will post a photo. It's nowhere as clean construction as a pair of Webster 2A3 PP amps I saw on eBay. They left plenty of room to work, and don't have integral multilple phono inputs. As a rule, am I right in assuming these transformers are potted with tar or something akin, making replacing leads a headache?
I will try the alcohol approach, as a matter of fact if I apply enough alcohol liberally to myself first, I become a lot more confident about tackling this! I just didn't think it would work on goo this old. First I am going to just take on redoing the bias and first cap. This cap needs to be isolated from the chassis ground, and preferably not with a can on the outside. Maybe I can hide a Solen underneath.
again many thanks.
again many thanks.
- Tubes / Valves
- Brook 22A restoration, HELP!!
