I built the bridged amp from the data sheet schematic and have a case of severe motor boating. Seems like the speaker will blow if I leave it on for more than one second. It does this even if the guitar is not plugged in. If I disconnect the speaker,I can measure 14.5 VDC at the speaker out jack. I'm getting 17 volts at the + & - rails.
I'm thinking I may have fried the chip as I soldered two connections without a heatsink .
What a dope
Prior to this build, I made guitar amps out of a single TDA2050 and TDA2030A. I had a few minor problems with them that have since been sorted.
Any ideas?
Don
Any ideas?
Don
where does the lower chipamp get it's inverted signal from?
Not sure what you mean. It's built as per schematic. Is there an error on the schematic?
I built it on perf board so the layout is not the same as the data sheet.
I have a small temporary heat sink attached to the chips (20mm X 200mm X 3mm thick) and it gets too hot to touch in about 30 seconds - without the speaker attached.
i did it...about 20 years ago
!!! And I remember I blew two midranges
(so sweeeeet !) with it ...of course : too much current running !
As far as I can remember ...
No good circuit for me 1
I preferred the much powerful version with four transistors plus two TDAs .
With a 100 W (always underrated !) 16+16 V supply ,that amp was a beast !
I can't see, on the poor copy of the schematic, where
Think this is legit? All you need is a 12-0-12 100VA transformer,right?
http://cgi.ebay.com/Value-Choice-TD...264?pt=LH_DefaultDomain_0&hash=item4aa5263040
Edit: I really like the part about welding the components together. No problem there as I already have a 220amp welder. LOL
Don
Don
Power amplifiers and perf board don't mix. Wiring inductance is very important as currents are high
Don
There are some words and phrases used in American which don't translate too well into real English so don't laugh too loud !!!!
- Chip Amps
- Bridged TDA2030A problem
