OK, here's one for the books... or my mind, anyway.
I have been listening with delight to a car stereo power amp. I have slightly modified it for better performance. I replaced the cheap op-amps for bifet op-amps, and run thicker wire from the B+ and B- to their respective places, and high quality speaker wire from the junctions of the output transistor resistors to the speaker terminals. The sound is nothing less than incredible. I am a tube amp enthusiast, but also have and made some solid state. But I have never really listened to a bridged amp before. This thing bridged sounds almost like a tube amp. Warm mids, clear unfrilly or unsibilancey highs, and good well defined bass.
I inadvertently left one chanel not quite properly heat sinked, so I think I blew open one of the transistors. But I can still use one channel as two separate ones.
Doesn't sound quite as good!
My question:
Since push pull cancels even order harmonic distortions, does bridging cancel out odd order harmonic distortions?
The sound is quite good!
Gabe
My question:
Gabe
Bridging does not cancel odd order distortion.
Odd order distortion is symmetric plus to minus, a good
example being clipping the output, and bridging does not
create a corresponding opposite, as it often does with
second harmonic.
second harmonic.
Thank you sir for the reply. I had thought that it wouldn't technically be different.
But why does it sound so much better than a standard push pull amp?
Gabe
Gabe
