Not unusually big - the efficiency is the same as a normal class AB amp. BTW I have changed the load to a more real-world 2.8 ohm + 2.8 ohms J so the current lags by 45 degrees. This works out to 4 ohms impedance. Resistive loads are just plain wussy for an amplifier to drive.
The curves below are:
Red - output voltage across load.
Green - Power across resistive portion of load.
Blue - dissipation in one mosfet, peak for SOAR, mean for heatsinking.
Black - load current.
DC input power would be 252.4 + 79.17 + 79.16 + opamp power dissiation.
Re: Mmmm..... symmetry....
Hi
It work ?
It is possible to use OPA541/9 for drive MJL3281 ?
thx
Circlotron said:Bridge version.
Hi
It work ?
thx
Well, it's been 6 whole years since I cooked up these circuits and I =still= haven't tried them out. Am I slack or what?
Yes!!!Well, it's been 6 whole years since I cooked up these circuits and I =still= haven't tried them out. Am I slack or what?
OTOH, that was only 3 posts ago..
Output waveform either side of load.
I also made a model, becouse I was thinking, that the crossover distortion will be quite much.
And here we go. 10 kHz and the xover distortion is huge (between the opamps and the MOSFETs)
i dont know any method to avoid it....
any toughts?
BTW I dont know, how the output graphs were so good from your simulation... Oh yeah at 1 kHz it looks good... Now I know...
cheers,
Tamas
For the term "Circlotron" there are more keywords (for the same topology) present: have a look to post #92 about
http://www.diyaudio.com/forums/soli...state-audio-amplifier-components-want-10.html
here more URLs to get a good overview:
http://www.diyaudio.com/forums/soli...e-ended-related-solid-state-output-stage.html (URL collection about post #1, "Circlotron")
http://www.diyaudio.com/forums/pass-labs/55361-supersymmetry-circlotron.html
http://www.diyaudio.com/forums/solid-state/23888-sumo-power-amp.html
http://www.diyaudio.com/forums/soli...-names-commercial-solid-state-amplifiers.html
SUMO NINE
AndAudio.com • ???? - <SUMO>????Circlotron??????? (scoll down for orig. schematic)
SUMO nine - k57117? ??? - ??! ???
SUMO nine (inside pics)
SUMO NINE
- BridgeClone with current-dumping circlotron afterburner :-)
