Hi. Unfortunately, my old transfomer burned ( shouldn't do that hobby...I'm easily distracted). I have to deal with a new one and would like to know if I can use a bridge with a CT the way it's shown on the diagram.
I first thought of a full wave for 300V and voltage doubler for 600V.
I also thought using a bridge to get 600V and start from there with a second line filter in a more "traditional way" with R-C-R-C...
Pierre
Pierre
Ok... The negative side of the bridge is grounded. Its positive side is used for the 600V supply and the CT becomes the "+" of the 300V supply...Since I intend to use a regulator, I'm not sure it will like that...
Thanks anyway.
Don't see how using a regulator, or not, effects it.
GEE ! Obvious . . . when you tellYou can even get a choke input supply (at 90% of RMS) and a capacitor input supply (at 141% of RMS) from each of them - by adding an extra diode to the cap input path. Four voltages from one CT secondary winding!
Yes, you're probably right but since it's a 21st Century Maida Regulator, I'd ask to Tom before to wire that way.
That's a very nice regulator. I've got a couple, just haven't used them yet.
- Tubes / Valves
- bridge with CT: can I do that?
