If your supply is just a transformer and rectifier, no caps, yes wire the negative lead (transformer CT) to the T1-RED-YEL connector, and wire the positive lead (rectifier output) the SW1 terminal marked O1 (closest to the T1-RED-YEL connector).
If your external power supply is filtered (caps and choke) wire the positive lead to the L1 terminal marked O1.
