Bridge Rectifier Temperature?
Now that it has been completed, I've been monitoring the temperatures inside my a40 amp. The heatsinks are hot, but you can leave your hand on them indefinitely.
What has me more concerned is the temperature of my bridge rectifiers. I haven't been able to find much discussion of acceptable rectifier temperatures. Using jh6you's nomenclature of:
"Blimey hot is 10 seconds hands on = 45 deg C.
Crikey hot is 5 seconds = 50 deg C.
Bloody hot is 2 seconds = 55 deg C.
X*?@! is 60 deg C."
I'd guess that the 5" x 1" aluminum strip attached to my bridge rectifier is approx 50-55 degrees. I've used aluminum strips because my amp resides in a wooden chassis and there is no room on the heatsinks for the rectifiers.
Is this an acceptable temperature for a generic, surlus 600PIV 35A bridge?
Thanks,
Eric
