Amplifier with schematic well-know as A+ schema 1
What do your think about this? schema 2
I think, that property of “filtration” distortions keep safe in schema 2.
Main preference is common ground in power supply if this solution used in multi-channel units.
After a quick scan,
I think that schema 2 is limmited by it's performance of the Class B amplifier. The class A amplifier sences one leg of the output, but the other leg is controlled by the Class B amplifier. Even if the Class A amplifier is perfect, won't the speaker be subjected to the limmitation of the Class B amplifier?
Thijs
Thijs
Schema 2
is nonsens - earlier start limited amp with rails 5 V and it will be by output power cca 1,5 W / 4 Ohm. Keep schema 1.
