Can I run the ICEpower 700AS2 in bridge mode?
I need to connect ONE 8ohm speaker and want to deliver no less than 800watt.
According to the documentation for driven two channels, this module achieves a power of 550watt @4ohm per channel (1Khz 1%THD).
I assume in bridge mode it should be ~1100 watt @ 8ohm.
Unfortunately, the documentation does not contain any information about this mode.
For other modules, such as ICEpower 300A2, there is a description in the documentation on how to run the BTL mode.
Thank you very much for your help.
In the documentation from the 1200AS2 module, I found information that the bridge is not possible, am I right?
but this still doesn't answer my question about the 700AS2 module10.2 Speaker Outputs The speaker output of the 1200AS is a balanced output with two active signal lines capable of driving complex speaker loads. As the speaker outputs are already in a balanced configuration, bridging of two channels is not possible.
Each channel of the 700AS2 is already bridged, so you can't bridge the channels. This is also why there is no mention of BTL operation in the datasheet - and in the description of the output stage (p. 23/fig. 21) it says "full-bridge" outputs and shows a BTL output configuration.
