Hi all,
I just finished 6 3886 PCB's from chipamp.com.
a few days ago I started connecting things up. when 3 PCB's where mounted and connected i decided to test these.
connected mains and nothing happened (this is good i thought)
when measuring the DC on output I have 7 mV on one channel, but 24 Volts (!) on the other two plus really hot chips (they started smelling, no smoke)
I disconnected everithing, checked the connections and resistor values, everithing seems to be OK.
could these be faulty chips? is there any way to find out what could be wrong?
I also checked the power supply's but this is all fine..
I did a search and found a few threads describing this, but could not find much help in there..
many thanks for your help..
I would suspect a couple of things right off the bat:
1) Are the chips isolated from gnd either by using the TF package LM3886 or by using an isolator on the T package?
2) Look for a solder bridge/short on your PCB.
I hope you find you trouble. I would suspect the hot melted chip is dead... But you may have gotten lucky.
chips are isolated,
there were no shorts on the PCB
i will start with the remainig PCB's .
is there any way to see is a chip is dead?
thanks for your tips..
