BrianGT LM3886 boards, Power Supply and Lightspeed Boards
SOLD
I have here 3 BrianGT LM3886 boards. One is unpopulated. The other two I build with Silmic II, Nichicon BP Muse, Caddocks and one Vishay S102. I was experimenting and never ended up plugging them in. Anyway you can finish my experiment for pretty cheap and find one of my toroids in another sale to power it all with. You can take all three boards for 15usd. Just the parts are worth more.
I also have 4 boards that were for the output of my first Lighter Note boards. The Lighter Note at that time was a better power supply and control scheme for the Lightspeed attenuator boards. You can control these as you would a lightspeed. Its probably been 8 years since I tossed these in the drawer. I dont remember why. Anyway maybe you are getting working Lightspeeds after removing the extra wires and adding on the normal Lightspeed control pot. You are probably getting matched LDRs and if not you have Lightspeed boards to go with the LDRs you match. The last board only has 2 trimmers soldered in. Nothing else. The price is fair. 12 dollars total for all 4.
The power supply board is the one that BrianGT sold for the Aleph Mini. This is a badass power supply. If you arent buying mine you should buy some from Chipamp.com anyway. They sell them for 7usd per board and really you dont need more for most amps on this forum. This supply has already 2x Nichicon Gold Tune 10000uf 35V caps on it as well as the .47R resistors and 2000ohm resistors. It has two of the 4 heatsinks for the diodes (I have two more of these in a bag you can have) and its got the parts for a LED to turn on when power is applied. Two WIMA snubbers as well. All in all probably about 20-25usd worth of parts. I'm guessing the Gold Tunes are running 5-7usd each. I'll sell it for 10usd.
