BR for FE166ES-R HELP!!
OK, I know that BR for these speakers is not the right way to go about it. but i recently finished some rough grande 6 clones for a friend and they sound sooo good that my 166es-r in ob just dont cut it for me anymore. I know I should bite the bullet and just build the recomended horn cabs. which i do intend to do. but just dont have the time now, so I was hoping I could get someone who is experianced with the box calc software to give me a decent starting point for a FE166ES-R ported box. Thanks for any input. and happy listening!!! :clown:
OK, I let WinISD calculate the missing parameters which should be close enough.
It´s not the most ideal driver for a BR just as the stock FE166E.
I put in the FE-167E (in a "Omega Grande 6"-like enclosure assuming ~20l) as a reference as you know that one.
As an alternative you could try a simple ML-QWT like here.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=51042&highlight=
That one will be a bigger floorstander but simple construction still.
If you´re interested I could try them in MJK´s sheets.
greets
The enclosure is 6.77l tuned to 92.39Hz. (0.239 cu ft.)
Port is 5cm in diameter and 6.51cm in lenght. (1.97"dia x 2,54" L)
(The FE166ES-R is the green line)
Before you start building:
You also have the possibility to put some series resistance before the speaker to raise it´s Q. That might probably be your best option.
I have to dig out the equation for that. hold on...
If you wanna try the BR, you can download WinISD and change the port-diameter so it fits something you have available.
Thinking about the ML-QWT:
If you decide something bigger you should rather go for either the horn or a tapered QWT. A straight one is probably not that ideal (low Qts).
My first attempt is with a series resistance of 3.3Ohm.
It raises Qes to ~0,318.
(now the white line is the FE166ES-r with added resistance)
Of course you´ll loose some precious sensitivity but if you get along without BSC etc. there should be enough left.
A theoretical ideal Qes for the driver would be around 0.5 which would result in a series resistance of 7,8Ohm but I´m not sure if that is advisable and/or has additional drawbacks to "just" sensitivity.
wow thanks a bunch! that was exactly what i was looking for. would like to stay away from bsc if i can ill try it without my main amp is single ended el84 so 2 watts needs all the help it can get. but i have a chip amp and a digital amp also. so power isnt all that important. and its really easy to add or remove a resister. thanks again ill try that out with some left over birch i have.
You may find that much or all of that 3.3 ohms is provided by
the output impedance of your amp.
And 2 watts? I'm listening to them right now at 1/2 watt peaks.
Yep, forgot to mention that.
Problem is you ideally would have to know the output impedance to properly simulate the driver, as volume requirements (at least for a BR) would change quite heavily with "tuned" Qes.
Of course you can always add some resistance but not get rid of it.
