I was just going to post that. From the US guy its $80 for LL1544A or the 1545A. Discounts at 10, 25, and 50. Each tier is 10%
After reading Lundahl site I only think they sell direct if you don't have a regional distributor. So that rules out anyone in the US, UK, and a couple others.
Rhysh,
Would you be willing to share the software program for the chip attenuator. I can program the chip I am just to dumb to learn how to write code. Or maybe too old.
Have any of you guys taken a close look at the Jeff Rowland amp from which this clone comes from. The innards of that amplifier are impeccable. The layout and organisation are superb. I really like the big output buss which is running above the board in front. It seems to be covered in epoxy or some thick paint. The tension bar for the chips is nicely machined. No wonder they cost 6800.00 dollars U.S. Lets see some of this kind of work in these amps.
Tad
Tad
So after looking at Shine7's page about the Lundahl trafo's I am not sure that would be good in my system as I don't use an active preamp. I am going from a PC via USB into a Buffalo32 then either single ended or XLR depending on the amp.
On another note where is everyone going to source the big caps from?
rhysh said:No, Im also working from the old wiki list.
If so, when are you planning to ship my boards?
If you haven't already shipped don't bother an send my $65 back instead.
I've completely lost faith in your ability to resolve this GB.
S
tryonziess said:Rhysh,
Tad
Are you wanting the code to program onto the chip, or the software used to create it?
R
I should have resolved the paypal situation by monday, i shouldnt be needing your address. I will let you know if i do.
Rhys
Rhys
Rhysh,
I have the programming material I just need the software to control the pga2310 device. You are using the Atmel chip, correct? The same code should work with the Pic device if not I will get an Atmel chip.
If I am to expedite these boards to the faithful I will need the names, addresses, number of boards purchased. I have 30 boards. Somehow that number does not quite fit. Do you not need 4 boards minimum for a stereo amp? It is possible someone wishes to build a BPA 150.
To those out there who propose to construct this thing. Remember using one board per channel still makes a very nice amplifier. That is 3 lm3886 chips per channel which will run fairly efficient speakers real hard. The balanced/bridged option is what Jeff Rowland choose. You do not have to adhere to it. Two boards in parallel, per channel, should drive 2 ohm speaker loads. Do not take this to the bank I am only speculating. A little help here AndrewT.
Tad
Tad
Rhysh, I have the programming material I just need the software to control the pga2310 device. You are using the Atmel chip, correct? The same code should work with the Pic device if not I will get an Atmel chip.
I am using the amtel chip, you will need the matching chip for my software to work.
I will get those to you tonight, i intended to do this yesterday but i never got round to it. You need 4 boards for a stereo amp, but some people have bought strange numbers.
Newark in the US has Rifa 47KuF / 40VDC @ 23.78 a piece. I am going to call to see what 25 would run for unit price? Who is interested I need 4!
EDIT
25 Peices brings it down to $21.78 a piece! Newark ships these from Farnell and puts a $20.00 overhead on the order so it would be 22.60 a piece if we order 25 pieces or more. I'll organize a group buy if peeps are interested.
EDIT
So Newark is the only source so far for these so far as Mouser and Digikey can even come close to prices for these type of caps ...
Mouser can get us down to ~28 @ 25 pieces for Cornell Dubilier same specs.
Digikey was more expensive then that. ($68)
HaLo6,
I'd be interested in some caps (2) but I'm still waiting on my kit to ship. Rhysh can I get a ship date ETA?...I'd like it to require a signature so we both know when it arrives.
- Group Buys
- BPA300 Round 2
