I'm sure this has been discussed before, so I apologize in advance.
I want to put some input attenuation on my BOZ in the form of a fixed resistor as my only source is a cd player and power is from a leach superamp.
I have been reading for a couple of hours now and can't seem to find a post that has a set value for the input resistor.
I have several good resistors in my kit and don't want to use a pot. I want to set it and forget it!!
Could some one here tell me what value to use??
Thank you😀
Thank you😀
I also forgot to mention that R107 was left out during the inital build as I am not switching input sources, cd only...
I am not sure if this will make a difference in the value for the input attenuation resistor...
One suggestion, would be to wire a 5K or 10K POT on the input. Use it to adjust the input level to your liking, measure it's value, and replace it with a resistor of the same value.
If you have tons of gain from your single source, you might also consider the B1 buffer/pre.
-David
-David
So I put 47K resistors at theinput for some attenuation.
While it is better, when I have the volume set at its minimum the music is still quite audible..
My concern is that If I increase the value of the resistor I may start limiting the bandwith...
I read that the top end will start to roll off...
Mr. Pass suggested 25K and I am already double that!!
What should I do?
What should I do?
So now i have 100k resistors in at the input and still there is volume when the output volume control is at its minimum...
How high can I go without degrading the sound quality??
You are way past it. A 10K in series followed by 10K or less is
about ideal.
If you can't get the volume to zero, look to the volume control pot
or the wiring.
about ideal.
or the wiring.
- BOZ input attenuation value??
