Boyoho and Formosa Audiomate
Anyone familiar with these brands?
Boyoho are seen in C-mark amplifiers, and looks interesting with good specs.
Formosa are used in SVS subwoofers, and have an interesting range of amplifiers with DSP.
I have seen Boyoho in a dutch webshop, but can't find it again -* anyone who can point me to that?
Anyone knows other products that use formosa?
Dear all,
These Boyoho amps are not used in budget amps!, please open up a budget class-d amp you will find something totally differend than the Boyoho amps.
these are quality amps with full datasheets, and a very good sound.
only downside I can think of is the low imput impendance of 4,7k
but this is easilly altered with a pre-amp.
Mies1971
looking at these amps the powersupply looks very weak, especially if you want to get these high power outputs. That is what I mean if you open up cheap amplifiers, the powersupply part is where they save money on. if you try to drive a large sub you will get in trouble.
Customer test Class-dmodule.com
Customer test says it all!
Quote "Nach kleineren Kabelmodifikationen (bessere Schirmung) und einer beträchtlichen Einspielzeit hat der Hulk klanglich zu den Anaview Modulen aufgeschlossen. Die Härte im Sound ist so gut wie komplett weg. Wir haben den Hulk in einer Hörsession der Wiener DIY Community ausgiebig getestet. Seine Spielpartner waren: Duetta, Big Needle und Little Princess und an allen Lautsprechern konnte er voll überzeugen. Die Lässigkeit und Selbstverständlichkeit mit der der Hulk zu Werke geht ist wirklich beeindruckend!" Source
Thanks to Google:
"After minor modifications cable (better shielding) and a significant break-in time has caught up to the sound Anaview modules of the Hulk. The hardness of the sound is as good as completely gone. We have tested the Hulk in a listening session of the Vienna DIY community extensively. His playing partners were: Duetta, Big Needle and Little Princess and all the speakers he could fully convince. The permeability and naturalness with which the Hulk goes to work is really impressive! "
