I have two decent floor standing 100w speakers from an independent business venture manufacturer of some years back, running off a run of the mill 75w Hitachi amplifier.
Last month, the base on one of them started cutting out completely and rumbling on and off at high bass levels, it took about a week to die, and now the bass cone is completely dead. The same happened to the other side a month later.
The sound from both sides was always sweet, no clipping/overdriven sounds. What could possibly happened for them to die so slowly, and what new ones can I get? I would really like to repair them, but I can't imagine what has broken.
It does sound strange how your drivers died within the same time frame almost,
I am sorry but i would suspect somebody else if you have been a careful owner, have u been away, They may have been subject to a party?
There a so many drive units these days replacments are not a problem, just the sizes and parametres can be.
This is my first time with speaker Electronics, and I must say I am completely confused.
I have tried measuring the crossover and various voltages with a standard industrial multimeter and the voltages I find are in millivolts, the only sensible re the only logical readout I can obtain is the ohms value, which is also confusing for me.
I have played my speakers very loud but the amplifier has a roof of 75W which is lower than the speakers and it is impossible to get the amplifier to clip. I have on many occasions played with the bass setting of the amplifier maximised and very loud. All the while though, the bass was crystalline.
It is a very old amplifier, and I am hoping it is as good quality as our 25-year-old hitatchi television. What should I measure & how should I use the multimeter to see what is actually happening?
An amp at max setting normally means you are well into clipping. I'm reasonably sure your amp isn't any different from others in that respect. What is the exact spec of the amp? 75watt continuous at 8ohm? Maybe 130Watt or so at 4ohm? And the woofer? Was that 100Watt nominal power or peak power? What is the stated impedance of the woofer (4/8ohm)?
First thing you can do is measure the resistance of the woofer. If it shows something at or near zero ohm, the voicecoil has shortcircuited, probably by melting due to excessive power.
To check for DC, you can connect the amp to a unit (midbass or bass, not too weeny), turn on the amp and without any sourcesignal present attach/detach one of the wires to the speaker to see if the speaker moves from its centre position. If it moves, there is a constant current comping out of the amp (DC) which forces the speaker in an offset centre position. This lowers the excursion capability considerably and DC also heats up the coil.
If those two check out, you might want to consider having a look at the voicecoil of the speaker to see if it was physically damaged due to excesive excursion.
Did you check the woofer leads ?
It is possible that the bass drivers were moving more than they were designed for ( especially at very low frequencies) and the lead out wire from the cones are broken.
You will need to remove the drive unit and look at the lead out wires that start on the cone and terminate on the chassis of the speaker. These do break sometimes especially on old drivers.
There are two wires coming out of the rear of the cone and terminating on the chassis.
If that is the case it is easy to get some flexible stranded wire meant for this purpose. Just resolder it in place of the old one. Get help from someone who has experience doing such things. You don't want a small problem from becoming a major disaster.
If you want we could also give you instructions in case you want to do it yourself.
Cheers.
Cheers.
The speakers are TDL Electronics rtl2 transmission line floor standing speakers.
8 ohms 100 W. When I got to these I remember reading they are 100 W per channel
http://digilander.libero.it/piani/cataloghi_tdl/tline_2.jpg
http://digilander.libero.it/piani/cataloghi_tdl/tline_3.jpg
the amplifier is an 8/16 ohms 10-year-old integrated CD player with an auxiliary coming from a balanced computer production audio card. It is rated at 150 W. and volume knob goes up to 10, but only values up to six have an effect on the volume. This is why I have never heard it clipping.
The speakers are from the late Nineties.
It was one of the best speaker companies in the UK for a while.
The worst treatment the speakers got from the amplifier was so that the frequency spectrum was distorted as if it was coming through graphic equaliser. All the sounds were still smooth. (I did not have sexual relations with that woman, Monica Lewinsky)
it seems I must have overloaded them! booo then again, it could be the the age.
I have just tried the bass cones soldered points with a bare amplified signal and all I could hear was the tweeter, it surprises me that the signal goes through the cross wiring to the tweeter, but this is probably normal.
I wonder what I should do next, possibly a comprehensive upgrade. I will research the best way to refurbish, I have some linkwitzd electrets.
Thanks for all suggestions regarding the cones wires and testing the amplified voltage, I shall certainly make sure it is all as you say.
Nice speakers, I used to love my TDL3s.
You can probably get some near replacement drivers from here:
http://www.wilmslow-audio.co.uk
dead woofers?
Same month? They must have been traumatized. DC is a good theory. I fried a pair one time, slow cooked, with a perfect amplifier that was dutifully amplifying DC is the source signal. Your hitachi probably has some protection for that but maybe not.
Hook up the woofer directly to a sound signal source - even a 1.5 volt battery to see if it jumps when you connect it. If it does not, its dead. Cut it open and small the coil - if it smells like burned insulation it was DC in which case you must replace your amp.
If it does work then the problem might be in a fuse (light bulb) in your crossover, or some other thing in the crossover.
Excellent ideas folks. I have attempted to reanimate the bass cones with electrical signals in various guises. I would have been very confused without all this wonderful advice. thanks!
I think that the driver's innards are fried.
The DC from the amplifier seems well balanced, with a pro audio
line signal amplified to maximum level I can hear very faint grey noise from just next to the speaker, and there is a reading of 60 Millli volts on the multimeter.
All this has made me realise of a possible cause, in that my very old budget amplifier has a short circuit on the auxiliary inputs which causes electric hum very loud sometimes. It is a c3 bass chord sound. I think it's harmless probably but I may have risked it. The dc measurement remains 60 milli volts when this humming happens. I guess I should tried to open the auxiliary inputs to isolate the false contact.
It's all confusing to me, I would have thought that loudspeakers required more volts than headphones... I guess i'll understand this one day.
I guess I will best get a new amplifier to be safe, time for a special treat
The cabinets are brilliant still, I wonder what I should do, anything with a real nice image representation and precise overbearing bass is good with me, any ideas what I should do with eight ohms tweeter/crossover/transmission line reflex cabinets (" |L| " cross section) ? Attached are the exact outlines of of the remaining sounds available:
thx
thx
Turn lemons into lemonade...
Now you can really get into the diy game by upgrading your speakers. I feel certain that for a very small amount of money you can make these sound better than they ever did.
If you can find the exact driver replacement on one of the links in the post above you should probably do it (boaring but safe) - otherwise you will have to reverse engineer some other driver to the box and crossover. This could be big fun. Also, as long as you are at it you could certainly get a better crossover and tweeter etc.
Let the experimentation begin!
First remove the driver completely.
You probably have done this already. You should check the speaker terminals with a multimeter or a battery with the drive unit disconnected from the crossover.
As mentioned earlier , if the speaker was burnt out due to dc the coil will smell like burnt enamel wire. That is a strong smell and lasts for a long time. If the lead out wires are visible on the front of the cone , scrape off ( gently ) some black paint that is usually on it and measure the resistance .
Intermittent operation usually means that there might be a contact , or 'cracked wire' problem.
Check this out THOROUGHLY before buying a new driver or destroying the old one. If you are convinced that the coil is BURNT there is no harm in carefully cutting out the dome on the front and inspecting and "smelling" the coil. That should confirm your conclusion or generate new doubts !
Cheers.
Cheers.
The other one has died as well now, of the same death, the braided wires under the diaphragm developed a bad contact recently at normal volumes.
I found where to get some replacements,TDL LF driver 172NS07 available from us at GBP26.25 plus VAT and shipment, each, which seems like an exorbitant deal, coming at over 70 pounds /USD150 delivered, from some cheap looking plastic moulded fragile drivers ? Is it really important than I match the drivers? Can't I just add any new good-quality ones in? Anything would beat what they had with them.
try wilmslow audio, they re-driver lots of older speakers that have suffered the same fate as yours. They can do the work for you, or just supply the parts. Do everything possible while your in there, cable, caps, etc. if they don't have the exact driver, they can prob offer you an upgrade alternaative. there are also drive unit re-cone companies in the UK, one advertises in Hifi world mag, sorry i cant remeber the co name.
Good Luck.
Good Luck.
- Both my base cones staged a gradual death in the same month
