Boston GT 50
Hi all
This amp doest not power on.Safe light on the front is on . Amp has no rail voltage.
Ther is no voltage on the gates of the power supply FETs.I am getting 13.02v on only
One pin of the PWM ic (will comfirm which pin later).All fuse test ok.Any pointers for this
Amp?
I tried that but no luck.I think pin 15 should have the same voltage with pin 13
But I still can not find out why voltage is not reaching that pin.I read on the dvd these
two pins are connected sometimes but on this amp they are not connected together
Sg3525
1: .00
2: .00
3: .00
4: .00
5: .00
6: .00
7: .02
8: .13
9: .21
10: .00
11: .00
12: .00
13: 15.71
14: .00
15: .11
16: .00
Lm339D
1: .27
2: .73
3: .86
4: .04
5: .00
6: 13.28
7: .86
8: .73
9:.27
10: 15.55
11: .24
12: .73
13: 6.27
14: .84
pics
Ok sorry about that. I number the pins on the 339 wrong.The resistor test good and the base of Q76 is connected to
Pin 3 of the 339 through 1500 and 90 ohm resistor.
339
Pin1: .73
Pin2: .27
Pin3: .15.55
Pin4: .24
Pin5: .73
Pin6: 6.27
Pin7: .84
Pin8: .27
Pin9: .73
Pin10: .86
Pin11: .04
Pin12: .00
Pin:13.28
Pin14: .86
If it's a BC850, you're correct. I'm accustomed to seeing 2G transistors in Rockford amps and they're PNP.
If it's an NPN, it doesn't appear that you have remote voltage reaching it. Follow the trace from the remote input through the various components to the base of this transistor. Where do you lose 12v?
