BOSS CE-4800D Parts or (Schematic)?
Guys greetings, I have a power to repair, customer says it was attempted after it first died but it seems they attempted the repair. However the parts doesn’t seems to be appropriate based on their arrangement. Can someone suggest power supply FETs and audio output FETs or a full or partial schematic? They had IRF540N in the PS and a mixture of P75N05 mixed batch in the output.
I’m trying to start up this amp power supply with 4 IRFZ44N (one each bank, uses 16 total), I have a solid drive circuit without none installed, but when the 4 is installed they get hot and the waveform degraded and seems wobbly. SG3525 is good and drivers (1027/1023 2ea) are 100 percent. Do I need to installed all supply FETs?
Am I having bad transformers?
Am I having fault along my DC rails on the audio circuit (I really don’t think it’s switched)
Is there bad rectifiers (uses 8pcs)
Someone was messing about the amp before so I’m not sure if I missed anything.
**I may have to isolate the power supply by pulling the anode/cathode and see its performance when I get back to it.
I'm assuming that you have the probe on 10x but the scope thinks it's on 1x and that's a 10v amplitude.
That would tend to mean you have a shorted transformer or something shorted after the transformer.
Does pulling the rectifiers change anything?
Do you have something you could use as a temporary heatsink (attached) or can you clamp the FETs to the amp's heatsink if you need to do more troubleshooting?
That amp looks like it has been wet inside.
I see lots of corroded solder joints and some white mineral deposits in the photos.
A good cleaning would certainly help, as the mineral deposits can be conductive and cause improper operation.
They can be removed with isopropyl alcohol and cotton swabs.
Corroded solder joints should be cleaned and resoldered as well.
Good luck.
A good cleaning would certainly help, as the mineral deposits can be condcutive and cause improper operation.
Good luck.
I’m not seeing any corrosion that would inhibit it from working at this point and there are clean square waves been produced without the rectifiers in, but whenever the fets are installed they get heated all is there is the transformers, pull down resistors series with two poly caps. There’s no shorting across drain and source no open resistors, all vias terminate properly and all diodes in spec.
