[BOSOZ] PCB fot the Audio input Selection board
I plan to build a BOSOZ and this case I choose to use the Audio Input Selection Board from Seungyun Lee.
You can see some pics from his job here:
http://www.passdiy.com/gallery/zenpre-p1.htm
or here for the full project ( attention the site is in Korean):
www.diymania.net
The problem was that for this board, he has made the PCB layer by hand and the scanned pics are not in a sufficient quality to make some good PCB:
Top:
Bottom
My board design is not new, is the same as the original one. The board was designed with EAGLE and looks like that:
In the attached file you find all EAGLE files and a copy in Gerber format!
The part list and the wire plan are available here:
part list
wire plan
Alex
  • ais.zip
My BOSOZ Relay Input Board
I have made a BOSOZ input relay Board, pictured below. It uses 4 Quad NAIS latching relays each which switches the pos and neg inputs for a single channel. This is my 1st DIY in about 15 years so I am new at it, but this appears to work, my preamp will be ready in a month or two.
Its 2"x4" which is really small and there is kind of a wacky layout. Don't hate me! The layout is the best I could do since I am using the free eagle pcb program which limits board size.
This is actually pretty good from a signal perspective (I think, hey this is my 2nd Board so what do I know), and is 2 Oz copper. All unselected inputs are grounded through 100K resistors. The diodes are there to protect reverse emf from hurting the relay contacts, as suggested by an app note I read once.
Inputs are selected with a 9 pin contact.
1. set input 1
2. reset input 1
3. set input 2
4. reset input 2
5. set input 3
6. ground
7. reset input 3
8. set input 4
9. reset input 4.
When I make a selection of an input through a momentary pushbutton switch, a diode matrix (on another board) fowards the appropriate 5 volts to the pins of this board and this board sets the relay you want and resets the 3 other relays. Its kind of foolproof (hopefully) but be forewarned, these relays are expensive.
Oh, and do you see my cool 9 pin mini-DIN connector! (actually its not installed on this board...yet, but you see it in the layout) Yeah baby! I told you I was new at this. Wait till you see my BOSOZ. I am definately dangerous.
Here is a combo-pic of the relay board.
How much are you guys willing to spend the money for a relay (DIL relays) ?
I recently open the RS components catalogs on relay, and there are some (small current, DIL) relays costing about US$11 !
Also, what characteristics are good for audio purpose?
I've seen some relays with various contact material:
- Ag on Au (silver on gold)
- AgNi + Au plated
- 92/8 gold/silver alloy over silver-palladium contacts
- Ag + Au clad
- AgCdO (silver cadmium oxide)
- etc.
What are the best contact material?
