HI this is my first time here I am building BOSOZ and am interested in how others set up the input selector.My plan is to use a rotary switch with an extra deck to connect in- to ground when unbalanced inputs are selected .Seems simple enough to me. Does anyone see a problem with this?
I used a rotary switch with 3 positions for Balanced (CD), unbalanced(Tuner) and still unbalanced(Tape). The unusued inputs on the switch (when in unbalanced operations) are shorted to ground. So you do all with one switch... but I do not forsee any electrical problems with your setup, except probabily a switching noise.mjounot said:HI this is my first time here I am building BOSOZ and am interested in how others set up the input selector.My plan is to use a rotary switch with an extra deck to connect in- to ground when unbalanced inputs are selected .Seems simple enough to me. Does anyone see a problem with this?
ciao,
Roberto Amato
Re: Re: BOSOZ input selector
Is it possible just, to connect " - IN ", and " - Out " to GND, when using it unbalanced ???
Re: Re: Re: BOSOZ input selector
NO it isn't. Only "-in" to ground NOT "-out".lykkedk said:Is it possible just, to connect " - IN ", and " - Out " to GND, when using it unbalanced ???
