BosoZ - damaged FETS ?
Today I finally could test my BoSoZ and get to listen to it. Unfortunately I've made something wrong, 'cause I measure 118 volt on drain of Q1 and Q2, where it should have been +30 volts. When turned on the amp plays (very quietly) for 10 sec and then fades out.
PSU works fine and I get 60 volt.
My amp is unbalanced only and I use 10K pots at P1 and zeners at input.
Any hints? Maybe I was not handling my FETS with care when I soldered them in on the board....
One more thing: I wouldn't worry too much about having blown a FET. The IRF610 is rated for 200V from drain to source. If you used the protection diodes at the gate, the FET should still be fine.
Or you could just replace it with another one 🙂
Everything's OK now, yet right channel Q2 gets 35 v, while the other three FETS get about 30 v drain, but I guess this is within margin.
Forgot to connect ground from PSU to line. UPS x 1000.
Still have a lot to learn about electronics.
Thanks. Looking forward to listening to it.
