Bosoz as head amp?
I was wondering if the BOSOZ would drive headphones very well, let's say the Sennheiser 600 I think around 300 ohms. I am in the process of building one right now and I thought if this was possible I could add an output switch which would divert the output to a headphone socket.
We've covered this ground before (do a search). You'll need to cut up your headphone cord and use a different connector to drive each channel differentially - the BOSOZ has a balanced output and headphones normally use a common center channel.
If you don't mind spending the money, HeadRoom at www.headphone.com might sell the balanced Cardas or Clou cables for the Sennheiser HD600. They carry these in support of their balanced-only output Blockhead amplifier (the best amp they carry for headphones).
However, I'll probably just take your approach and feed the unbalanced outputs to a stereo headphone jack.
It is perfectly possible to drive the headphones differentially,with just a little modification.Cut wires from the terminal jack mostly 3.5 or 6.35mm.Then solder 2 mono plugs,one on each channel.Then you can go directly from the balanced outs of the ZLS.Another little extra adaptor ( mono jacks goin' on a stereo standard one ) allows you to use the headphones as before on conventional equipments 😉
Best regards
Anael
If I go the common earth route that means that the two power supplies (assuming dual mono construction) will have to be connected at the output to the headphone common earth.
I can't seem to think of a problem arising because of this , what do you think?
The big question first is:
Does your headphone wire has a seperate return wire (or 'ground' or 'neutral' wire) for each channel.
If so, then you can use NAR's idea.
If not, then you may need galvanic isolated amplifiers for each channel...
Did I just cleared things up, or made it worse?
gr,
Thijs
I am confused with your suggestion thijs.
Assuming I don't want to drive the cans differentially using the + and - from each channel separately, what harm can it do if convert the balanced out to unbalanced by shorting - to earth and then connecting the two channels earths thru the common earth return of the 3-pole jack of a headphone?
