BOSOZ 2 tube power
So I really like the sound of the BOSOZ but I also like the ambience of my old ST70 in the bedroom. (kinda like a bedroom fireplace). I'm just a tag along with no design capability yet, but I would like to rebuild the front end of the ST70 to accept balanced input. Does anyone have any design suggestions? X-tube maybe?
The way I have choose is the transformer one, I mean I use
input transformer in front of input stage of my tube amp
and connected in balanced mode to my BalZen, it works pretty fine.
and sounds good too. Have a look at Lundhal or Sowter and you will
find the transformers you need.
- 10k /10k, 1:1, and a 10k res. connected to the secondary should be a good option.
friendly
Flyinfader
Input transformer
Thanks Flyinfader,
That's a solution I've considered and might come back to, but in the meantime, if I'm going to spend some money, I'd like to think about something different. I think it was Carpenter that said in a post that appyling X to a tube amp was not so difficult.
I'll be out till late Sunday so thanks for any replies till then.
Charles BL
Tube Zen
Anthony,
Tube and mosfet, is that tube zen or Yin Yang? I have'nt done Zen yet so your project might be right for another room. In the meantime, I'm thinking of this driver... as shown on the vacuum state page. But I wonder if it can be x'd?
How about the other way around. Can somebody design a BOSOZ with tubes ? I imagine it should be quite easy.That way you can power an Aleph in the balanced mode which is best. I haven't really researched thoroughly but most tube pre-amps seem to be unbalanced.
Not sure if this fits the bill,
http://web.vip.hr/pcb-design.vip/6c33c-b.html
Anthony
