T tozeyana Member Joined 2016 2023-06-14 6:34 pm #1 2023-06-14 6:34 pm #1 Hi Guys, please help me, my Bose Companion 5 right speaker channel is not working. Any help troubleshoot? Attachments bose-companion-5-dsp-schematics.pdf bose-companion-5-dsp-schematics.pdf 1,021.2 KB · Views: 155 bose-companion-5-io-bose-pcb-top-and-bottom-board-layout.pdf bose-companion-5-io-bose-pcb-top-and-bottom-board-layout.pdf 477.1 KB · Views: 117 rayma Moderator Joined 2011 2023-06-14 7:28 pm #2 2023-06-14 7:28 pm #2 Most likely to be bad solder connection, but also check fuses and connectors. Possibly some of the electrolytic capacitors are bad. Poke around on the boards with a non-conducting stick with power on, to find bad connections. Reactions: tozeyana You must log in or register to reply here.
