bose 601
i agree with cowanrg, there are feew in the favour of bose here, but you have a question and i will try to answer.
firstly do you have any cabinet pictures or plans?
if you do thenjust copy directly from that.
if not, you need to measure the TS parameters of the drivers, when this is done then you can put those parameters into winisd or something similar and get the best tuning for the drivers, then simply build a box with the required box volume, and do not worry if the box is larger or small than the original bose box as they are designed for asthetics not for sound.
hope this helps
