I need to find a boost controller to drive a switching MOSFET that will allow me to get +48VDC output, and am going a tad bonkers wading thru data sheets from the various semi vendors.
Perhaps someone who has done something similar could advise a part?
Input voltage: +10VDC to +18VDC
Output voltage: +48VDC
Output current: 4.5 amp (external MOSFET probably required, so a healthy drive current is needed)
Output ripple: 200 mV max
Must have a chip enable
Switching frequency in the 500 KHz to 600 KHz range
Max 50% duty cycle
Low side current sensing needed
No input/output isolation required
Any suggestions for a suitable PWM controller for the above would be much appreciated
Thanks,
Lukas
Max 50% duty cycle
Thanks,
Lukas
