Bonsai’s X-Altra MC/MM Phono Preamp
George, You shouldn’t have to worry about that since the BOM with the Mouser and RS part numbers (per the supplemental data published on the audioXPress website) calls up the right size part (same on all my PCB layouts BTW)
RB.14/.32 or say RB.5/.3 as examples: -
The bigger number is the diameter in inches, the smaller number is the lead spacing
Hello Terps
In tne UK I got mine from the local supplier (listed on the Linear Integrated Systems website) and Jan Didden sold me some as well.
My suggestion to all builders is you just email Linear Systems - in many cases you can buy them directly off their website.
Note that the PCB will accept either the plastic 8 pin SOIC or the 6 leg metal can version.
LSK389
Thanks Bonsai. There are couple of places in the states who can supply of the shelf but carriage is expensive. So I have contacted Linear and Micross is the main UK distributor. Which grade is most suitable A,B,C,D to buy ?
Has anyone ordered directly from LIS on this side of the pond? DigiKey has a min of 5 for $7 and change each. I don't need that many so I'll decide which route to go depending on price and stock from LIS. I may end up with extras that I would be willing to ship to someone in need for this project.
