Why not?
CURRENT
and it needs to be between strict limits for the regulating action of the choke input filter to work.
If the current goes low then the voltage rises as it starts to approach the the value given out by a capacitor input filter (1.414* instead of 0.9*)
ClassA average draw is OK, but the rail currents move towards zero and 2*Iq as output current increases. This will demand that the capacitors smooth out the dips enough that the choke NEVER sees anything as low as zero current.
CURRENT
I would like to wish everyone here a Merry Christmas and a Happy New Year. I'll probably be relatively off-line until mid next week.
Cheers!
Bob
Cheers!
Bob
Not if you go balanced.
Patrick
Patrick
Hi Euvl,
did you mean a pair of bridged amplifiers from the SAME supply?if you go balanced
It needs to be designed properly. The inductor should be well above the critical inductance for the average (!) current but this is not too difficult in a Class A circuit.
Correct, this could happen in failure mode, so you should choose capacitors with a sufficiently high voltage rating.
In other words you still need sufficient capacitance but this is the same with a capacitor input filter. It is not an issue that the inductor sees a zero current as long as it is only for a short period of time. See also this post: http://www.diyaudio.com/forums/showthread.php?postid=658596#post658596 : For a properly dimensioned LC filter the time constant will be lower than the lowest audio frequency. Calculate an example, enter it in PSUDII and use stepped load, this will give you an indication of how much the voltage will rise or dip. Worst case would be a 16 Hz signal (half a cycle, i.e. ca. 30 msec) and the actual inductance being the bare minimum critical inductance.
ingrast said:
You could have taken the easy way of leaving all this to fade away, given the net offers no face to face relations.
Best wishes, Rodolfo
Yes, that would have been easy, but so much time and energy was expended to leave such a loose end dangling. As Christer pointed out, one less mystery in the world.
Thanks and happy holidays to all.
Mike.
No. I meant :
http://www.diyaudio.com/forums/showthread.php?s=&postid=658958&highlight=xed#post658958
Patrick
No. I meant :
Patrick
Hi Euvl,
is that the one you referred to as Xed?
It looks very like bridged from the same supply if each output is connected to either end of the same load.
Can you explain the difference?
My name is Patrick. You may wish to address me so.
Yes.
Bridged amps from the same supply is like what JLH showed in Fig 4 of his postscript in 1970. You convert a single-ended input signal to differential (+/-) and drive two individual amplifiers which are totally independent on each other, other than a common ground, and optionally but not necessarily the same power supply.
An X'ed amplifier (as patented by Nelson Pass, but also published by Kaneda amongst others) uses a diff pair frontend to link the two halves of the bridge, and thus interacting to cancel distortion better, according to Nelson. There are plenty of explanation of the X circuit on the Pass forum or at his websites, as well as the patent, which describe the principle much better than I can do here with reasonable effort. It only works with negative feedback, however.
I have built different versions of at least 3 variants of the X topology, including the Aleph-X, JLH-X as linked, and a MOSFET version of the JLH-X (also previous published on the Pass Forum PLH thread). They all work very well, with very constant current draw even loaded fully by a dummy speaker at maximum swing.
Patrick
Yes.
Patrick
Hi Euvl,
thanks for that explanation of the differences.
What I can see is that an Xed is a bridged amplifier designed to be integrated with the feedback crossed over and in this case a shared supply.
These types of bridged amps do indeed have virtually constant current draw and would be ideal for a choke input filter.
And have all even harmonics largely cancelled (if you have perfectly matched transistors).
Whether that is a good thing is a matter of taste. For me no question yes.
Patrick
Patrick
Hi Andrew, EUVL
An inductor filter will be OK when used on a Class A amp. even when the current goes to zero (which it will only do so if one side cuts off, and the amp would be clipping) if there is a large capacitor as well (after the inductor). This will serve to "fill in" the missing load.
So it does not seem necessary to use an X-config. nor bridge, actually.
As a large capacitor is already part of the PSU it still seems worth considering an inductor filter!
The transformer voltage needs to be increased by root 2 times 1.1, but the current requirement can reduce proportionaly. A minimum load can always be provided by a dummy-shunt transistor. This could be normally off but cut in if the voltage increases (such as during test when an amp may be disconnected).
cheers
John
cheers
John
Interestingly, Viola Audio Labs still uses choke input filters in the power supplies of their pre- and power amps. Quote: “The Bravo uses a choke input filter type power supply with a generously rated 2kVA mains transformer. Four 80,000μF filter capacitors are located in the power amplifier chassis to provide optimum power supply decoupling. The Bravo's choke input filter design power supply produces far less Electro-Magnetic Interference than the capacitor input designs most commonly used in power amplifiers. “
In the past, Cello audio used choke input filters and I believe an earlier model of an Ayre power amplifier also had them. I have a couple of pictures of the power supply of the Viola Bravo power amplifier but for some reason I can’t upload them.
MRupp said:In the past, Cello audio used choke input filters
Martin,
Colangelo did not use aircoils for the dual choke input in the Encore 150 either.
AndrewT said:What I can see is that an Xed is a bridged amplifier designed to be integrated with the feedback crossed over and in this case a shared supply.
Actually this is true only for Class A versions of such a circuit.
If you bias X/balanced/bridged output circuits in Class B or AB,
the draw of the amplifier will vary with the current to the load.
Hi Nelson,
thanks for reminding our readers that we were talking about current draw of ClassA amps only, since it was a while since posts241 & 243 passed by.
Nelson Pass said:Shows how short my memory is. 😎
Oh Oh, sounds like a truckload of Cabernet went down the Pass.age over Christmas.
The next diy-SE : ZinV10
Nelson,
This is still a very useful point to bear in mind, even when the context of the discussion was Class A.
Happy New Year,
Patrick
Nelson,
Happy New Year,
Patrick
- Bob Cordell Interview: Power Supplies
