I notice that a lot of PCB amps here use the pcb screw terminal blocks.
Is this a better method of attaching wires to the board than simply soldering the wires to the board?
It would seem with the screw terminal that it would either work loose from vibration or oxidize after a while.
Are they used just because they are easy to work with?
I will be building the Simple SE after I get my board from Mr. Anderson so I'm doing some leg work before starting.
Thanks!
Tom
Thanks!
Tom
