BLZS and SOZ problem
I want to build BLZS preamp and SOZ amp.
1.My CD player no balance output and the SOZ need balance input.so I want modify the BLZS preamp.input unbalance signal but balance output.it can work well,the attach file has modified BLZS SCH.
2.if build 10W SOZ,the 8 Ohm resistance use dale 50W is OK?
I used the current source (sink) that NP showed in his A75 front-
end: a zener being fed by a resistor attached to the positive rail,
and filtered with an RC. This establishes a relatively stable
voltage which I used to drive the gate of an IRF510 (two,
actually: each gain MOSFET gets its own in mine.)
It works well, but in my can't-leave-well-enough-alone mania I'm
thinking of cascoding the gain devices.
Erik
Question
Follow this circuit, unbalance input and balance output, i imitate one and test, but the +output level and -output level is difference, near 0.2V(input 0.5V), is problem? i remember Son of Zen document also same like this. (photo is + - output level addition)
