Bluetooth speakers made by Creative
Hello, everyone!
I am not sure if “full range” is a right place to post my question. Mods, please, feel free to move it somewhere more appropriate.
Anyhow, I’d like to start a thread on Bluetooth speakers.
Sorry if this is a sacrilege to discuss these not-even-near-HiFi plastic boxes in this respected Hi-End Audio forum. However, they do exist and they are very handy sometimes, and they surely can be modified to get some half-decent sound out of them.
I’m tinkering with Creative Bluetooth Speakers, models D80 and D100. They are, probably, the cheapest BT speakers available (AU $45 and $70), but for their price they are surprisingly well made. I believe that they have some potential for improving. Besides, if you stuff them up while modding, it’s not a big deal at this price.
If someone is interested (and The Moderators will not remove my post as Blasphemy), I can post some pictures of the internals and some basics on parts/schematics.
Please ask me some questions to get this post rolling.
Thanks for your response, guys.
@ Planet10 and Pano (respected Mods):
Thank you for your suggestion. There is even easier way of doing it. I was contemplating to buy BT audio module on e-Bay and put it in some old ghetto blaster. BT modules come from China and cost around $15 for external one (in small enclosure) or just a PCB-kit. It went nowhere, because:
a) Shipping time from China is several weeks
b)I don’t have a ghetto blaster.
Then I saw Creative D80 ad on the net and decided that for $45 I can’t go wrong. It doesn’t have unnecessary things like cassette player, radio etc., it’s lighter, smaller and looks better. I can’t make decent quality box with front panel/speakers/amp/power supply for $45, sorry.
Speaking of fidelity of Bluetooth link – it is not too bad, really. I wouldn’t suggest using it in HiFi setup, but for portable audio it is quite acceptable (for my ears, anyway).
@Alex from Oz:
I have some pics of D100 on my workshop computer; I will post it later today or tomorrow.
As promised, some pictures of the internals of Creative D100 speaker.
It’s ported enclosure with 3-inch wide-range speakers driven by TI class D amplifier TPA2012D2. Amazing fact (for me, anyway) is that there is no heatsink for 2x2W amplifier.
All electronics runs off 4XAA cells or external 5V power pack. Bluetooth receiver module is based on 57F68 chip made by CSR – perhaps, some BlueCore family.
The enclosure is sealed pretty well with some kind of foam everywhere, but there is neither sound absorbent padding (or whatever you, pros, call it) nor vibration damping coating. The sound is pretty ugly, therefore. The upper flat surface of the case vibrates a lot. If I press on it with my hand, the sound becomes a bit better. The bottom surface does not noticeably vibrate, because of rigid battery housing.
Any suggestions on improving the acoustical properties of this plastic box? Or maybe I am barking at the wrong tree? I have almost zero experience with audio design.
There are some things you can do to improve the box.
IME you will improve the sound, but it will leave you hungry for more.
So treat this as a learning adventure.
If I was going to keep the box as is, here's what I would do:
1. Buy 6-8 packets of Blu Tac and line the inside of the box with it.
Then listen to the sound.
2. Cut some 4 mm x 2 mm rectangles of duct tape and stick them
on the back of the box around the port opening in the EnABL pattern.
Listen again.
3. Add a very small amount of stuffing being careful not to obscure
the port. Listen again and add or remove stuffing until it sounds right.
There is plenty more, but start with these.
Alex
Alex, your reply has simply swept me off my feet. Blue Tack as a vibration dampener!!! That is bloody ingenious! To think of it – it’s perfect! Non-hardening, very viscous, easy to apply, cheap – the list just goes on! Up yours, Jaycar, with your bitumen-based lining. (for non-Australian readers – Jaycar is electronics DIY shop)
Only one thing about the lining – doesn’t it rob me of the internal cabinet volume? I heard that volume is important in vented boxes and the port is tuned in accordance with it.
Or maybe I will compensate for this loss when adding some stuffing? BTW, is synthetic stuffing for toys any good? I’ve got plenty of this, as my dog rips my kid’s toys on a regular basis. Can I wrap it in some acoustically transparent fabric to prevent it from getting into the speakers and port?
About EnABL pattern – does it go on the inside or on the outside of the box? I know nothing about it, there is a bit of googling/homework for me to do here.
Funny thing about the back panel of this box is that I do not feel any vibration there at all. Could it be because of that factory protective anti-scratch film is still there? (I did not bother to peel it off). The plastic thickness is the same everywhere, I guess. I have a strange feeling that the fact of the port being linked to the top panel (see pictures) has something to do with severe vibration of the top. Then again, I know nothing about speakers.
Thanks again, Alex. I’ll get stuck into it and keep you posted.
Yes, the Blu Tac lining will reduce the volume but adding stuffing will help to
compensate for this somewhat. Toy stuffing should be fine in this case.
Just make sure that you tease it out so that it is not to densely packed.
EnABL for ports is best on the inside of the port. However the long slot ports
like the one on this unit are too fiddly given the unit we are working with.
Best bet is to stick the pattern around the port opening on the back of the box.
I guesstimated the port size from your picture and have drawn up a very
rough pattern to give you an idea of how to do it. The blocks closest to the
port should be about 1mm from the edge. Refer the attached pic.
BTW, Norton All Weather Tape (Bunnings has this) would be even better than
duct tape but it costs nearly three times as much.
Alex
Administrator
Joined 2004
All good advice, but I would scrap the plastic box. Build something out of MDF or plywood.
It maybe never be great, but you will have built something and learned something. That's how you get started in DIY. You can learn just as much from what doesn't work as from what does.
And you might just build something you really like. ;)
@ Alex
With our current outside temperatures in high 30s I can not even dare to go to my workshop (it’s 10-15 degrees more in there). Therefore I’ve done nothing about my box so far, however itchy I am to try your Blu Tac recipe.
In the mean time I’m reading some basic theoretical stuff on vibration damping under harmonic excitation (for simplicity) to figure out what is more beneficial – actual viscosity of the dampener or mass increase of the oscillating surface. You wouldn’t have an answer ready, would you?
@ Pano
It is really flattering for me to be mistaken for some youngster who has never built anything before. Only last 15 years of my business are dedicated solely to finding and eliminating design flaws in electronic equipment; before that I used to design and make things. Not much audio, though.
I am convinced that any ready-made product can improved and brought to desired level of quality/functionality with much less efforts than manufacturing it from the scratch. All those factories have manufacturing equipment far beyond the wildest dreams of DIY person. Besides, the design engineers are not always stupid. Often, but not always. I’m coming from my experience.
Even you guys on this Audiophiles’ forum do not make your own speakers – I mean, conventional speakers (transducers) - magnets, coils, baskets etc.
Happy New Year, everyone!
