I have a pair of TDL near field monitors with no bass, there is sound coming out of the tweeters.
Is the fault with the crossover or the bass woofers?
Varies.
An 8ohm woofer will measure 6-8ohm DC, a 4ohm woofer 3-4ohm. If the meter shows either short circuit (0ohm) or millions of ohms, you've got a problem.
