My current set of DIY loudspeakers consists of the following:
Morel MDM-55 Mid (200 watts RMS/285 watts max)
Morel MDT-30S 1-1/8" Soft Dome Tweeter (200 watts RMS/280 watts max)
Dayton ST255-8 10" Series II Woofer (250 watts RMS/350 watts max)
And a:
Dayton XO3W-625/5K 3-Way Crossover 625/5,000
All powered by a Europower EP1500.
The failure is caused by over powering, I know this, just can't help it! What I can do (besides turning the volume down) to help prevent this? Perhaps a higher wattage mid or some sort of protection?
To my untrained ear this is a good sounding setup. Morel doesn't sell a higher wattage model, and from my searching no one else does either!
Any opinions or suggestions?
Andy
And a:
Andy
Well there are two way the drivers could have failed, mechanical or electrical failure.
The first is when the tinsel leads delivering the signal to the voice coil break due to over excursion.
The second is when the voice coil overheats and breaks.
Both problems can be solved by setting a higher Xover point, or steeper slope.
longblock454 said:
..... And a:
.....To my untrained ear this is a good sounding setup.
Andy
Hmmm .......... I doubt it ......
http://www.partsexpress.com/pdf/295-110.pdf
Not the ideal choice to cross to a 2" dome midrange.
The Dayton c/o is completely useless and wrong.
Your probem is likely mid over excursion that might be fixed by using
a larger cone midrange but the set will likely still sound poor, off the
shelf crossovers do not work well at all.
I'd suggest a Seas midrange driver and a properly designed c/o.
3-ways are never easy, lots of information below.
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spkrbldg/
http://www.zaphaudio.com/
http://www.rjbaudio.com/projects.html
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
http://www.humblehomemadehifi.com/
http://htguide.com/forum/forumdisplay.php4?f=39
If you can't redesign the crossover, put a 3db l-pad in between the crossover and the mid. 2ohm resistor in series and a 20ohm resistor in parallell. That will pad the mid down just a bit and protect it. In addition, the generic crossover will "see" a flatter impedance and work better.
Polyswitch with a 10 ohm resistor in parallel.
EV has used this method for 20 years to prevent their tweeters from blowing up.
The polyswitch is the same as a strait wire so no audio passes thru the resistor. Once the polyswitch trips, then the signal passes thru the resistor which reduces the level about 6dB.
Only cost a few $$$ for the parts and goes together easily.
http://www.partsexpress.com/webpage.cfm?webpage_id=3&CAT_ID=41&ObjectGroup_ID=237
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=017-10
All,
I am thinking of buying this:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=248-668
A Behringer 3-way active crossover. I have enough amps and the above unit is about the same price as building two custom crossovers.
Any reason not to go this method?
- Blown my 3rd Morel MDM-55, suggestions?
