Blocking capacitor as a high pass filter?
I would like to power a single speaker driver with an amp and need to block everything below say 100hz or so.
I'd like to build a power amp for this speaker whose design already includes blocking capacitors at its input terminals. Has anyone out there used blocking capacitors at an amps input as a 1st order high pass filters by changing the caps value?
I'd love to hear about it.
Almost every amplifier has an input capacitor, and this capacitor
together with the input resistor forms a first order HP filter.
To calculate the capcitor value you can use the formula:
freq = 1/(2*pi*R*C).
Hope it helps,
Udi.
Yes but I think you'd be more interested in the node that is tied to the input transistor's base/gate instead of the preamp's output. You should determine R and C based on the total resistance to GND and the total capacitanc to GND from this node. So your typically R would be the Rin of the BJT/FET in parallel with the base/gate biasing resistors. The typical C is the input blocking C. If you have a non-zero or non-incredibly small output resistance from your preamp then things get complicated but it's doubtful.
