I am about to order the BK-16 from madisound. Should be going with FF165K before they runs out. But I am not too fancy about T90A as it can't be cab mounted if I decide to change cab next time.
What do you guys think about FT96H? I guess it can be easily place resting on top of the BK-16 without any stand. I can also cab mount it next time if I want to. But will it pair nicely with FF165K in BK-16?
Series a 1uf mundorf silver-oil and parallel a 22ohm or a 47ohm resistor as crossover for the FT96H. Will it work?
