Hi everybody, I'm trying to understand.
Having buildt several version og P3A, sounding great i'm thinking of a BJT version as it is the way most of you suggest for more power. But can the outputdevice handle twice the current ?
Say at 32W the current is 2A - the voltage is 16v RMS, rigth ?
If you BJT 2 modules the voltage is 32v RMS, the current 4A, and 128W. 8Ohm example.
4A will then run trough both modules rigth ?, and you have to calculate with this designing your output-stage right ?
Any comments are wellcome, - thanks.
