BJT help
10A current capability guarantees linearity through 2A. The Big Deal about the D44/5 is their beta stays high down to Vce=1V. That doesn’t happen with higher voltage types or with generics like TIP41. The price paid is power handling is terrible above 15V or so, but that’s a don’t care.
Reactions: Alessandro Dalto
I've just found this, is inherent?🤔
Seems he doesn't recommend them.
The problem is the “atrocious” SOA ratings. Good for low voltage, but only for low voltage. They look tempting for a high performance amp running off +/-25V rails but they will go bang - even before getting hot. On a 12-18 volt single rail, fine, even in class A. 20 may be a stretch in class A. They do hold at +/-15 in AB, even driving 4 ohms. But under no circumstances go above that driving “speaker” impedances. In such low voltage applications, you DO want a device that doesn’t fall apart performance-wise at low Vce.
