I have 2 bits of 25mm thick perspex here, one is circular and is 303mm wide with a 7mm hole in the centre, the other is square and 300mm. The circular one was going to be used as a turntable platter hence the hole in the middle. It would need some more machining but gives you a start.
Circular piece - £20
Square Piece - £10
Delivery is £7 each (or both packaged together
Square Piece - £10
