Bipolar/MOSFET CFP output stage
Joined 2002
Has anyone tried using a low power MOSFET transistor with a Bipolar power transistor in a CFP stage. Any comments about its bias stability and the performance?
I wanted to use a Hitachi TO220 package MOSFET with a Bipolar output device like a 2SC3281/2SA1302 ( or similar ) . The idea being that I get a simple high input impedance stage with plenty of current drive capability in the output devices.
Biasing will be like the usual transistor Vbe multiplier.
Essentially like the circuit at:
http://sound.westhost.com/project3a.htm
Q5 and Q6 will be MOSFET's.
Any suggestions?
Thanks,
Ashok.
The difficulty here would be the high capacitance of the mosfet, which is loading the VAS. I think the more resistive loading presented by a BJT would be preferable here...
I suspect you may be able to raise the input impedance of the output stage by doing the opposite of what you plan... that is, use a BJT to drive the gate of a mosfet power transistor. Mosfets can easily handle the current, although you will sacrifice some efficiency since you won't be able to swing as close to the rails... But I believe this approach would probably yield an improved input impedance, allowing more linear operation of the VAS.
Thoughts on the above, anyone? I haven't run the numbers on this one yet, but it's in my list of considerations for a new amplifier. The other issue, of course, will be stability... CFP isn't known for being the most stable beast. In this respect, perhaps someone with a bit more experience building mixed bjt/mosfet CFP stages can comment? For what it's worth, I've built a couple of fairly low powered mixed bjt/mosfet CFPs before, and did encounter some oscillation, but YMMV.
hifiZen said:
Mosfets can easily handle the current, although you will sacrifice some efficiency since you won't be able to swing as close to the rails. The other issue, of course, will be stability... CFP isn't known for being the most stable beast.
I minimised the problem of not being able to swing to the rails by soldering one of those little 3 volt coin-shaped batteries like on your pc motherboard, in line with the fet gate. Positive toward gate. This meant the gate threshold was effectively lowered by 3 volts so that means the drain can swing down 3 more volts before the cct runs out of puff.
For stability, try putting a bit of resistance in the emitter of the bjt to lower it's gain a bit. Worked for me at least.
Hi ashok,
Have you tried using SPICE to model the output stages you're considering? I've been using the freeware LTSpice from Linear Technology to evaluate power amp output stages, and I must say the results have shed a lot of light on the problems. Models for the On Semiconductor equivalent of the 3281 and 1302 are available. If you use International Rectifier MOSFETs, I can provide you with some models that aren't generally available on the net. I don't think I have any Hitachi models though.
For evaluating stability, I pick a worst-case capacitive load. In my case, I used 2uF, a value that Bascom H. King has used for many years as a torture test for amps. As a result of all this, I ended up abandoning bipolar output stages altogether, as the output impedance is quite inductive at high frequencies. This causes a high-Q resonance with the capacitive load, which has horrible effects on the stability of the amp.
Another poster mentioned high capacitance of the MOSFETs. The IRF 610 and IRF 9610 have a typica gate-to-drain capacitance of 15 pF at 25 Vdc. I was pleasantly surprised by how low this is. The gate-to-source capacitance is high, but the Miller effect at a gain of 1 mostly cancels this out.
Mosfet driver bipolar out
You guys are as confused as barking duck.......
The McCormick amps use Hatachi 2SJ76 and 2SK213. The gate to source turn on is low enough that you lose little voltage swing. The VAS boot strap circuit like in http://sound.westhost.com/project3a.htm
would take care of this on the negative swings and it wouldn't take a nuclear physicist to design a circuit for the positive swings, batteries...... please! I would rather have the VAS stage clip than the output when you run out of voltage swing.
All amps (FET BJT Tube) with loop negative feedback have inductive output Z. I won't state the obvious reason why. Put a snubber on it like the real designers do.
A BJT will have the VAS stage see the load impedance divided by Hfe of the output stage. Most speaker loads are not very resistive, especially at cross over frequencies. The guy asking the question knows more than the people offering advice as is often the case.
Actually, I was referring to the open-loop output impedance, not closed loop. No feedback, just an output stage all by itself. A simple complementary emitter follower circuit with the MJL3281a and MJL1302a biased in class AB at 40-45 mA shows 60 degrees of phase lead in its output impedance at less than 300 kHz. By contrast, the IRFP240/IRFP9240 pair has an almost purely resistive output impedance out to about 1 MHz. With tha bipolar output stage and a 2 uF load, simulations show about 9 dB of peaking in the small-signal open-loop gain (again, of just the buffer), with a very sharp dropoff of phase. With the MOSFETs, the result looks much more like a single-pole rolloff.
Reactions: Globulator
I am thinking to build a class-A amp that way. The main reason is that the FET diver transistors have a quadratic transfer function (in the ideal case). That means the bias current trough the output can be 1/4 of peak output current needed in stead of the usual 1/2 peak output current to keep the amp fully in class-A. The sum of quadrates (of bottom and top fet) will give a linear transfer function.
And for those concerned about capacitive loading of the VAS: The input cap of a source follower is:
C_in = C_gd + C_gs x (1-voltage gain)
Since voltage gain is near unity the effective capacitance of C_gs is very small at the VAS.
Output Phase
The phase angle depends on the source impedance seen by the output. With each base seeing about 10 ohms with respect to ground you should see 60 degrees at over 3 MHz.
X1 3 5 1 QSC3281 { }
.SUBCKT QSC3281 1 2 3
* TERMINALS: C B E
* 200 Volt 15 Amp SiNPN Power Transistor 12-03-1991
Q1 1 2 3 QPWR .67
Q2 1 4 3 QPWR .33
RBS 2 4 9.5
.MODEL QPWR NPN (IS=1.63P NF=1 BF=150 VAF=254 IKF=12 ISE=1.34N NE=2
+ BR=4 NR=1 VAR=20 IKR=16.5 RE=22.1M RB=4 RBM=.4 IRB=5.556U RC=4.84M
+ CJE=481P VJE=.6 MJE=.3 CJC=312P VJC=.22 MJC=.2 TF=5.33N TR=204N)
+ XTB=1.5 PTF=120 XTF=1 ITF=9.6)
.ENDS
X2 6 8 2 QSA1302 { }
.SUBCKT QSA1302 1 2 3
* TERMINALS: C B E
* 200 Volt 15 Amp SiPNP Power Transistor 12-03-1991
Q1 1 2 3 QPWR .67
Q2 1 4 3 QPWR .33
RBS 2 4 9.5
.MODEL QPWR PNP (IS=1.63P NF=1 BF=130 VAF=254 IKF=11 ISE=1.34N NE=2
+ BR=4 NR=1 VAR=20 IKR=16.5 RE=12.1M RB=4 RBM=.4 IRB=5.556U RC=4.84M
+ CJE=1.09N VJE=.6 MJE=.3 CJC=708P VJC=.22 MJC=.2 TF=5.33N TR=204N)
.ENDS
R1 4 2 0.22
R2 1 4 0.22
V1 3 0 DC=50
R3 3 5 775
R4 5 0 10
V2 0 6 DC=50
V3 7 0 DC=0 AC=100
R5 4 7 100
R6 0 8 10
R7 8 6 775
.END
Fred,
Thanks for posting that. I'm baffled about the difference. Here's the netlist that LTSpice is putting out. I also have 10 Ohm base resistors, and 0.33 Ohm emitter resistors, with a supply of +/- 56V.
I'm still seeing 60 degrees at 300 kHz. I'm trying to attach the image, but it looks like it needs to be a URL?
Andy
* F:\Program Files\LTC\SwCADIII\My Circuits\PA_output.asc
Q1 N008 N007 N006 0 Qmjl3281a
Q2 N009 N004 N005 0 Qmjl1302a
R1 N006 out 0.33
R2 out N005 0.33
R3 N007 N002 {Rbase}
R4 N004 N003 {Rbase}
V1 N002 N001 {Vbias}
V2 N001 N003 {Vbias}
V4 N008 0 56
V5 0 N009 56
V6 N001 0 {Voffset}
I1 out 0 0 AC 1
.model NPN NPN
.model PNP PNP
.lib F:\Program Files\LTC\SwCADIII\lib\cmp\standard.bjt
.param Vbias=0.56
.param Voffset = -0.0356
;op
.ac dec 100 1000 100e6
.param Rbase=10
.backanno
.end
Models from standard.bjt:
.MODEL Qmjl1302a pnp( IS=5.35257e-14 BF=10000 NF=0.85 VAF=29.806 IKF=1 ISE=6.75503e-13 NE=1.13462 BR=0.1 NR=0.75 VAR=298.06 IKR=10 ISC=1e-16 NC=3.31217 RB=1.9617 IRB=0.1 RBM=1.9617 RE=0.0001 RC=0.185509 XTB=0.1 XTI=1 EG=1.05 CJE=1e-07 VJE=0.4 MJE=0.491105 TF=6.44974e-10 XTF=1000 VTF=2.05556 ITF=279.371 CJC=5e-10 VJC=0.400004 MJC=0.23 XCJC=1 FC=0.1 CJS=0 VJS=0.75 MJS=0.5 TR=1e-07 PTF=0 KF=0 AF=1 Vceo=200 Icrating=15 mfg=OnSemiconductor)
.MODEL Qmjl3281a npn( IS=6.5498e-11 BF=139.247 NF=1.00176 VAF=46.776 IKF=10 ISE=7.75232e-12 NE=3.34341 BR=4.98985 NR=1.09511 VAR=4.32026 IKR=4.37516 ISC=3.25e-13 NC=3.96875 RB=11.988 IRB=0.111742 RBM=0.102914 RE=0.00127227 RC=0.209833 XTB=0.115253 XTI=1.03146 EG=1.11986 CJE=1e-07 VJE=0.4 MJE=0.450375 TF=7.04629e-10 XTF=1000 VTF=2.06045 ITF=41.8156 CJC=5e-10 VJC=0.4 MJC=0.85 XCJC=0.959922 FC=0.1 CJS=0 VJS=0.75 MJS=0.5 TR=1e-07 PTF=0 KF=0 AF=1 Vceo=200 Icrating=15 mfg=OnSemiconductor)
Fred,
Well, I put your models in LTSpice and changed my circuit to use them. The result is that I'm now seeing the 60 degree phase angle of Zout at about 3.7 MHz.
I'm not sure what to think now. That's a huge difference. I got the models I was using from the On Semiconductor web site too. I did add the Vceo, Icrating and mfg fields, but as far as I know, they're only used by the LTSpice UI.
Play with value of the source impedance that the bases see.
I'm using 10 Ohms as you are. As I mentioned, I used your BJT models in my circuit and got results similar to yours. So there's more than a 10x discrepancy between our models for the frequency at which the phase of the impedance is 60 deg. This leads me to wonder, "Which model is right?". Out of curiosity, which SPICE are you using? Did the model come with your version of SPICE or did you get it from the net? Could On Semiconductor (whose site I got my models from) have screwed up and put unverified, incorrect models on their site? I also got their models for the mje15032 and mje15033 driver transistors. Maybe I'll play around with them a bit and see what kind of results I get.
Could you try the models I posted and see if you can duplicate my 300 kHz number?
This is really bugging me 🙂.
Intusoft Spice models from same probably for Toshiba since they are from 1991.
Toshiba data sheets:
http://www.audiodesignguide.com/tra/toshiba_2sc3281ds.pdf
Explanation of model parameters:
http://newton.ex.ac.uk/teaching/CDHW/Electronics2/userguide/sec3.html#3.4.4
From above reference:
BF ideal maximum forward beta
http://www.onsemi.com/site/support/...odels_194,00.html?startPos=501&outputSize=50&
BF=10000 !? I don't think so...........
Can anybody tell me what diy stands for?
The plot thickens...
In my quest to find out the reason for the discrepancies between my data and Fred's for the output impedance of a complementary emitter follower using the MJL3281A and MJL1302A, I compared the individual transistor parameters in my models and Fred's and found quite a few differences. So I thought I'd try to get another data point. The site:
http://www.orcadpcb.com/pspice/models.asp?bc=F
has more SPICE models, including a file called on_bjt.lib, which is also provided by On Semiconductor. I compared the data in that file for the MJL3281A and MJL1302A, and found the parameters to be different from what you get when you download the individual SPICE models by going to their site with the data sheets for the specific part number you're looking for. So I replaced my MJL3281A and MJL1302A models with the ones from on_bjt.lib. This time, the frequency for which the phase of the output impedance is +60 deg came out to 483 kHz. Still a huge difference from the > 3 MHz number I got from Fred's models.
I'm really bugged about this, because it makes the difference between "Only happens way above the unity loop gain frequency of the amp, so it doesn't matter", and "Is capable of completely ruining the stability of the amp with a large capacitive load unless the unity loop gain frequency is scaled way back".
Yes, that looks very suspicious - when I do the DC operating point the base current indicates a DC beta of about 450 at Ic=45 mA. This is way, way off from the data sheet value. This is for the 3281a, using the model from on_bjt.lib, which has BF = 844.614. The model for the 1302a in on_bjt.lib has BF = BF=72.008, a much more believable number. Are they using random number generators for these models or something?
This INTERESTING! Could you please draw a graph of this to edify a non-mathematical dufus like me?
/Circlotron - can't cut it with the big boys when it comes to hard sums. :bawling:
Well, I rounded up the models for the 2sa1302 and 2sc3281 from yet another simulator. Here are the models:
.MODEL Q2SC3281 NPN(IS=10.000E-15 BF=155.65 VAF=100 IKF=9.2028 XTB=1.5 ISE=54.325E-15 NE=1.3056 BR=10.787 VAR=100 IKR=1.8561 ISC=106.69E-15 NC=1.6728 NK=.55624 RC=26.745E-3 CJE=2.0000E-12 CJC=534.41E-12 MJC=.33333 TF=8.0821E-9 XTF=3.1968 VTF=21.461E-3 ITF=169.59 TR=187.91E-9)
.MODEL Q2SA1302 PNP(IS=21.479E-12 BF=136.48 VAF=100 IKF=19.980 ISE=21.504E-12 NE=1.3784 BR=329.48 VAR=100 IKR=19.980 ISC=4.3670E-9 NC=1.4264 NK=.72845 RC=93.301E-3 CJE=755.31E-12 MJE=.33333 CJC=1.1417E-9 MJC=.33333 TF=1.2802E-9 XTF=10 VTF=10 ITF=1 TR=10.000E-9)
With these models, the output inductance of the complementary emitter follower is even less than that obtained using the models from Fred's simulator. The output impedance phase angle never even hits 60 degrees, but maxes out at about 42 degrees at around 10 MHz before heading down into capacitive territory.
So my conclusion is that the models provided by On Semiconductor for the MJL3281a and MJL1302a are totally wrong. This applies to both the models available from their support web site, as well as the ones they provide in on_bjt.lib that are referenced from the PSpice web site. Using these models caused me to reach an incorrect conclusion regarding the output inductance of power amp output stages using these devices.
Spicy - masala!
We come across the 'spicy' problem of "which Spice program is best " , yet again !
Can someone start a discussion with sample results if needed, on the different Spice programs around. Starting with free programs to demos to fully paid ones ( for DIY users).
I am afraid I cannot comment on anything other than XSpice from Circuitmaker. For simple simulations it is OK. XSpice models are a bigger problem. I don't think this (XSpice) is expected to be a comprehensive analysis program - maybe I am wrong.
We need to sort out this 'problem' as we can see this 'Spicy' problem in so many threads.
Can all those who are experts (or not) give in their two bits.
Lots of us laymen will benefit.
Thanks.
Ashok.
Maybe we can move it to a "Spicy issues" thread.
