Hi guys,
my english is bad so I bounce presentation and my sentences will be short and some time these last could be strange.. I beg your pardon for this...
I have a echorec binson e4t (I attach the schematic). If I increase "length" (feedback) I have only max 4/5 repeat even if I put on max the internal trimmer.
how can I try to edit in the feedback circuit for add the number of repeat?
thank you and excuse me for errors and ignorance
Luca
Luca
thank you very much for your reply..
I checked the pcb..there are some difference with the schema..the resistence that you substituted is already 470k and, start from pedal point we have: 10k res, pot 47k, 13k res (instead of 4,7k), 13k res (istead of 4,7K), trim 47k, 470K res (instead of 150K)
You want to make that resistor *smaller*. Add another resistor in *parallel*. Start with a same-value resistor (so it acts like half value). However 470k seems awful high and you may have to go to 150k.
- Live Sound
- Instruments and Amps
- Binson e4t feedback
