Bigbottle MM/MC Hybrid Valve Phonostage PCB
@Bigman80
Hi mate.
I have a question regarding “LOAD” positions, left and right, on board - what is the function?
Could you explain me a little bit, please.
Kind regards.
S.
The load sockets are to use with MM or MC carts. If you need more Capacitance for your MM carts, you can add a capacitor there, or if you need 400ohm for you MC cart, you can add the requisite resistor there instead.
I usually install RCA socket and make loading plugs to insert with whatever value resistor I need, soldered to the RCA plug.
What about sch?
